I have shortened the cable from the previous 25cm down to 10cm and now it works fine.
However I am surprised by such a limited range.
May be it is due to the cable quality (plain flat cable)?
Should I use shielded cable?
Is there any mean to have longer (1m) cables, perhaps using drivers?
Thank you all.
I too am surprised, since my cable is just over 2M in length, home-made from Cat5 Ethernet cable, connected to a home-made COM1 port at the back of the PC case (Asus doesn’t supply a COM1 port as standard, but the header is on the Motherboard) and it works perfectly.
In addition, I’m also NOT using the Velleman-recommended un-regulated PSU. I’m using the 12V regulated supply from a modified ATX PSU…and this too works perfectly.
If it helps any, my port settings for COM1 are as follows:
9600 Baud
8 Data bits
No Parity
1 Stop bit
No Flow control
XP SP2 Driver = Version 5.1.2600.0 dated 01/07/2001
I/O range = 03F8 - 03FF
IRQ = 4
I recommend reading this if the Serial Port settings are unclear societyofrobots.com/microcon … uart.shtml
But if this board uses UART like the K8076 the settings are not important, becouse RS232 is a protocol based upon UART.
