That is strange. You can open the scope and check if the GND wire is properly soldered to the GND connection of the BNC connector. If this is not the problem, then we’d recommend to send in the scope for repair. Please note that problems due to use beyond the specs (e.g. overvoltage) are not covered by warranty. Please return the scope to:
