How to send and recieve "analog" signal with 433 transmitter
Does anyone know how to solve this question?
Scenario:
Im about to build a homeautomationset with VELLEMAN products.
Thinking about to combine the K8056 to the RX433N and the connect it to the K8061.
This should give me possiblities to use a 433 transmitter to send 8 different ON/OFF to be read by a computer.
Its possible to send both digital or analog signals to the computer.
But can I send analog signal with a 433 transmitter?
To explain… Lets say I have a lamp in a room controled by a dimmer.
If I would like to send a signal that tells me how bright the light is with a phototransistor?
So if I combine a 1signal remote with a phototransistor instead of a regular button.
Is this possible?
Please help me if anyone can…
Sending an analog signal is not possible.
How would you go about it then?
Is it possible to send a value? From 1 to 10 for example?
It must be possible in some way right?
