How do I get replacement transformers for a Velleman K4040
If I wanted to order a powerr transformer 8D002 or an output transformer ZD043, are these orderable?
If not, what are the specs I would have to look for to purchase replacements ? Thanks…I think there is an issue with the power transformer as I measure 4.5vdc at all taps out of the transformer to the screws…do you know what would cause this ? Thanks
Transformer only output AC voltage not DC.
Thats what I meant …sorry …Still can I get the specs on the power transformer?..
how do I replace the parts? Can I order one ?
…I love the amp but in many ways its been the amp from hell. I finally get rid of the buzz and the hiss…and if I put the cover plate on I get a buzz again…UGGGG
That still doesn’t address why my voltage is very low low…at the taps. The funny thing is, the amp sounds great but this can;t be good…thanks in advance…
Power transformer order code is TR4040
Output transformer order code is ZD043
You can order these from any Velleman distributor but please note that this is not an item they stock.
They will have to special order it for you. Not all distributors are willing to do this.
Thank you ! I have verified, my transformers are ok…but good to know the information…Thanks
