Help to carryout alteration/modification in the PCLAB200se
Dear forum members
I am using velleman 4channel data logger/recorder for my for acquiring the voltage of a solar panel every day from morning 6.00 AM to Evening 6.30 PM .I have developed a program to auto start and auto stop of the PCLAB200-se during the specific time. The program starts automatically and the opening welcome page of the PCLAB200 se appears.Here my problem starts .
I has to select manually the k8047 tab [/b]and none tab and ok tab to enter in to the 4 ch recorder/logger page and again I has to press run tab to start logging.
This very much impedes/cripples me in automatically starting the PCLAB200se and capturing the data at specific time every day since the logger is located in the field which is far away from my residence.
The data captured should also be automatically saved in a time stamped generated file is another thing to be done.
Hence to implement the above said modifications I need suggestion from the form members .I request the forum members to help me which would immensely facilitate me to automate my data capturing work.
With warm regards
Paldurai kasi rajan
[quote]I has to select manually the k8047 tab [/b]and none tab and ok tab to enter in to the 4 ch recorder/logger page and again I has to press run tab to start logging.[/quote]You may use the K8047D.DLL instead of the PcLab2000SE to get the data from the PCS10/K8047.
Please see:
velleman.eu/support/download … CS10&type=
K8047/PCS10 DLL and example to write your own software
and
DLL for K8047 (PCS10) for faster communication
