Heat bed not communicating with software
Hello guys, I need help with my printer. I assemblied all the parts and everything works… except the heat bed.
I checked the connections and wiring and everything is ok, however I cant get it communicate with repertier; its not even showing up in the the program.
Any help and advice would help me. Thanks in advance for the responses.
[quote=“AkaRed”]Hello guys, I need help with my printer. I assemblied all the parts and everything works… except the heat bed.
Any help and advice would help me. Thanks in advance for the responses.[/quote]
What do you mean? The printer doesn’t show, or the heatbed?
[quote=“ichbinsnur”][quote=“AkaRed”]Hello guys, I need help with my printer. I assemblied all the parts and everything works… except the heat bed.
What do you mean? The printer doesn’t show, or the heatbed?[/quote]
The heatbed doesnt show. Thanks for reply
Are you saying it is not in the software or does it read 0C
If it reads 0C there is an open between the thermistor and the control board.
Check you solder joints.
I had the same when i did not plug in de power.
Connect with control board in repetier, so there is only usb power to the board.
On the tab manualy control printer, the icon of the heatbed is not present…
So have you connected the main power?
[quote=“Wrong Way”]Are you saying it is not in the software or does it read 0C
Check you solder joints.[/quote]
it doesnt even show the temperature. All the soldering joints should be ok.
[quote=“dutchronnie”]I had the same when i did not plug in de power.
So have you connected the main power?[/quote]
Yes I did connect it to the main power, however it still doesnt show any temperature or any controls on the manual control
Could you post a screen shot?
The heat bed is not showing in repetier. Any advice would really help me. Thanks
On the upper right side of the screen next to the axis controls there is a scroll bar.
Slide it down you find the controls for the extruder fan and bed.
You can also slide the log area down to see it as well
[quote=“Wrong Way”]On the upper right side of the screen next to the axis controls there is a scroll bar.
You can also slide the log area down to see it as well[/quote]
Well the heatbed doesn’t show there either (should have taken a better screenshot)
Could you post another one?
