Hi. I have bought a VM130 which I intend to hook up to my existing garage door opener. The receiver part is not a problem, my question relates to the transmitter.
I am intending to strip out the PCB from the case, remove the 12V battery, solder a link across one of the switches (so it is permanently ‘pressed’ ), and then connect the -ve battery connection to earth, and the +ve to my headlamp flasher, then insulate the VM130T PCB and hide it inside the fairing (this is on a motorbike ).
I have 2 questions.
Can you see any problems shorting out the switch in this way?
The voltage of the bike electrics can vary from about 12.2 to 14.6VDC. Will this be too high a voltage for the VM130T (bearing in mind, it will only be a momentary push on the headlamp flasher.
Thanks in advance for any answers.
