Thx VEL327!
What fill density did you use for the above print the standard 20%?
Have you tried a high density print for example 50-100%?
Can you plug two printed Lego bricks together do they fit? I had to adjust the model in blender to fit. Cause for some reason the inner dimensions don’t fit while the outer dimensions fit perfectly(compared to an original LEGO brick).
I could post the code but I wonder why should I get another g-code from my standard Vertex Repetier-Host Cura slicer than you? I haven’t touched these settings at all.
