I’ve set the temperature for the extruder to 220 deg C ( to print ABS - is this the correct temp?)
When printing starts, the temperature defaults to 190 deg C
I’ve changed the printer settings and clicked on “apply”.
What am I missing?
Thanks.
What am I missing?
Thanks.
Remove all temperature commands from the start code in Slic3r.
[quote=“stratafied”]I’ve set the temperature for the extruder to 220 deg C ( to print ABS - is this the correct temp?)
What am I missing?
Thanks.[/quote]
Default temperature can be set in Printer Settings (Repetier).
This value overrules the one in Slicer settings…
You could download and import the ABS ini file.
http://www.k8200.eu/downloads/files/downloads/k8200-abs-standard-new.zip
Thanks for your suggestions. I edited the G code after slicing (the correct line was easy to find) and that fixed the problem in the short term.
I’ll try and import the .ini file and see what happens.
