Dusk dawn timer
Hi I am trying to build a switch which activates at dawn and gives a 12v pulse to a motor for about 6s may be longer then switches off. Again at dusk switches on for 6s then off I am looking at kiy MK125 but need some sort of timer attached any help please
Almost impossible to make such a circuit with one or more kits.
This calls for a custom solution, preferably with e.g. a microcontroller.
Thanks do you do custom solutions ? could you provide me with a circuit diagram so I could buy the components ?
Thank you for the reply
Sorry, no custom design.
Woudnt a dawn to dusk kit MK 125 coupled with a relay timer MK111 would that work ?
Regards Andrew
No. MK111 is an interval timer, it loop continuously (i.e. blinks).
What about the MK125 with the VM141
