Got a 8055 usb board, is there any guide or Tutorial just to get me kick started?
Cheers
Cheers
Sorry, no tutorial.
Don’t want to scare you, but this is a level 5 kit.
It requires extended programming skills, e.g. you need to be familiar with Windows programming under VB, Delphi, C++ etc… The implementation of a DLL in your code is required. Of course, you also need reasonable electronics skills. We’d suggest you study the source code of the test program for the K8055. If will allow you to examine the way the card is controlled. A compiler is required to open, edit and compile the source code. This is not part of the kit. Good luck.
