Crawling Bug Mini Kit Spesification
I am looking into purchasing the ‘crawling bug mini kit’ (MK165) and i require the folloing relevant information un order to produce a full spesification as part of an engineering course that i am currantly participationg on. I require the folling information and any help would be much appreciated:
Performance (ie speed, light sensitivity levels)
Environment (ie for use in the home)
Maintenance (ie easy to replace parts)
Aesthetics (ie colours)
Ergonomics (ie easy clean surface)
Physical features
Electrical features (ie 9volt battery)
Safety factors (ie 3Amp fuse to protect circuit)
I’m sure you’ll understand that these specifications are not available.
This is a € 19.95 minikit…
