The K8006 home module has 5 slots that u can use , now i would like to use 2 K8046 touchpanels that i would like to use parallel (control on 2 different places) to control the 2 light modules (module1 slot 1 to 5 , Module2 slot 1 to 3). (hope someone is still getting this)
Here are my questions :
-The touchpanels have got 8 open collector outputs can i put them parallel or is this a bad idea , they are all set up as momentary switch , so except for the signal going from one panel to the other one i don’t see any problem , or should i place diodes to prevent a signal going to the second ones out?
-my second question is , becouse the K8046 panels have 8 outputs and the K8006 Has got 5 Inputs , can i use slot 1 to 5 on one module board and use 1 to 3 on the other ?
If anyone can help me with this it would be much appreciated .
PS 1. yes i am a newby
2. No i don’t speek/write english a lot so answers in Dutch will also
do fine .
