Ok that’s a good thing.
If you disconnect the end stop from the board you should be able to measure 5 volts from the pins.
I hope you didn’t damage the board.
[quote=“rplevoets”]I checked the wires from the board to the end stop and everything is correct.
When i press the end stop, the beeping sound of my multimeter stops.
I hope nothing is broke after the wrong wiring i did.[/quote]
I measured here and there is no voltage.
I measured between the contacts of other endstops and there was 5V.
Is the board broken then?
Such a small color mistake. I didn’t see the colors very well (colorblind).
[quote=“Wrong Way”]Ok that’s a good thing.
I hope you didn’t damage the board.[/quote]
Something is going on
Unfortunately I don’t have the schematics available
But if I remember correctly the is a pull up resistor that may have been damaged.
I have send the board to Velleman.
I hope they can help me.
