Combine different Vel interfacecards on one pc
Is it possible to connect and control 8x K8061 cards and 2x K8000 without interrupting each other?
And same question for the K8055
(Or is there a simple way to convert the analog output of a K8061 to 8 digital outputs?)
[quote]The K8061 is an USB card and K8000 an LPT port connected card. [/quote]There shouldn’t be any problems to run both at the same time.
You can use 4x K8055 and 8x K8061 in the same PC.
[quote](Or is there a simple way to convert the analog output of a K8061 to 8 digital outputs?)[/quote]It is possible to use analog outputs as digital. Just send the max value or zero to the analog output pin. - Maybe a simple subroutine is good to use to convert the digital byte to analog values…
Thanks for the answer about the combining of the interface cards. It’s very clear now.
I know you are here for Velleman answers only, but maybe you have a great answer. 8)
What i mean with
is, can i convert 1x 0-10V output to 8 Digital outputs.
I found several ADC IC’s but the all have a Serial out in stead of a parallel out.
Anyway, Great support on this forum. Thanks Velleman :wink:
In the K8061 you can use the functions SetAnalogChannel(…) and ClearAnalogChannel(…) to get digital output from the analog outputs.
