Cant deactivate Pullup on the endstop
Hi I have tried last week to join a capacitive sensor for Bed Leveling the k8200. Since my sensor is faulty but apparently I need to connect the normal switch again.
In the configuratition.h i had commented the zendstop_min enabled.
Yesterday I simply upgrading the firmware back to the old settings. After the update with a closed switch 0.48 volt and will not appear 4,5 volt as on the other Endstops. I have somewhere to reset this? I seems to be the Pullup is already active.
Regards
Jan
[quote=“janpsx”]Hi I have tried last week to join a capacitive sensor for Bed Leveling the k8200. Since my sensor is faulty but apparently I need to connect the normal switch again.
Regards
Jan[/quote]
What do you mean?
#define zendstop_min enabled
has nothing to do with endstop pullups.
Can it be you resoldered the switch incorrectly?
Compare your connections to the working switches, or simply swap the connectors to figure out.
