Box for VM8095
Does Velleman have a suitable box for VM8095, like G738 for K8095?
That’s for you to find out. When available, they mention it in the specs. Otherwise you have to look for yourself what housing suits you best (they always give the dimensions of the PCB in the specs).
The box G738 from Velleman is perfect for K8095. It´s only to cut or drill
holes in the front and back, even the studs inside fits perfectly to the mounting holes on the circuit board.
Therefore I wonder if Velleman is offering a box that suits the VM8095 in the same way.
Thanks for the valuable information. But there is no box with already pre-drilled holes and cut-outs as far as the information on the website tells us. And I don’t know of such a box either.
