Hi, have posted my settings below - you can see from the comment if I have changed a setting or value.
#define AUTO_BED_LEVELING_GRID_POINTS 2 is the line that sets the number of probe points. If set to 2 it checks 2*2 so 4 points, but all should be contained within the area you defined.
[code]//===========================================================================
//============================= Bed Auto Leveling ===========================
#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line)========UNCOMMENTED PC========
#define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled.
#ifdef ENABLE_AUTO_BED_LEVELING
// There are 2 different ways to specify probing locations
// - “grid” mode
// Probe several points in a rectangular grid.
// You specify the rectangle and the density of sample points.
// This mode is preferred because there are more measurements.
// - “3-point” mode
// Probe 3 arbitrary points on the bed (that aren’t colinear)
// You specify the XY coordinates of all 3 points.
// Enable this to sample the bed in a grid (least squares solution)
// Note: this feature generates 10KB extra code size
#ifdef AUTO_BED_LEVELING_GRID
#define LEFT_PROBE_BED_POSITION 50 //========CHANGED PC========
#define RIGHT_PROBE_BED_POSITION 150 //========CHANGED PC========
#define FRONT_PROBE_BED_POSITION 50 //========CHANGED PC========
#define BACK_PROBE_BED_POSITION 150 //========CHANGED PC========
#define MIN_PROBE_EDGE 10 // The probe square sides can be no smaller than this
// Set the number of grid points per dimension
// You probably don't need more than 3 (squared=9)
#else // !AUTO_BED_LEVELING_GRID
// Arbitrary points to probe. A simple cross-product
// is used to estimate the plane of the bed.
#define ABL_PROBE_PT_1_X 15
#define ABL_PROBE_PT_1_Y 180
#define ABL_PROBE_PT_2_X 15
#define ABL_PROBE_PT_2_Y 20
#define ABL_PROBE_PT_3_X 170
#define ABL_PROBE_PT_3_Y 20
#endif // AUTO_BED_LEVELING_GRID
// Offsets to the probe relative to the extruder tip (Hotend - Probe)
// X and Y offsets must be integers
#define X_PROBE_OFFSET_FROM_EXTRUDER +48 // Probe on: -left +right ========CHANGED PC========
#define Y_PROBE_OFFSET_FROM_EXTRUDER +30 // Probe on: -front +behind ========CHANGED PC========
#define Z_PROBE_OFFSET_FROM_EXTRUDER -0.90 // -below (always!)========CHANGED PC========
#define Z_RAISE_BEFORE_HOMING 4 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 5 //How much the extruder will be raised before traveling to the first probing point.========CHANGED PC========
#define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points
#define Z_RAISE_AFTER_PROBING 5 //How much the extruder will be raised after the last probing point. ========CHANGED PC========
#define Z_PROBE_END_SCRIPT “G1 Z5 F12000\nG1 X0 Y0\nG1 Z0.0” //These commands will be executed in the end of G29 routine.========UNCOMMENTED & CHANGED PC========
//Useful to retract a deployable probe.
//#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell
//#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you’d like.
//If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk
//The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it.
// You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile.
// #define PROBE_SERVO_DEACTIVATION_DELAY 300
//If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing,
//it is highly recommended you let this Z_SAFE_HOMING enabled!!!
#define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area.
// When defined, it will:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled
// - If stepper drivers timeout, it will need X and Y homing again before Z homing
// - Position the probe in a defined XY point before Z Homing when homing all axis (G28)
// - Block Z homing only when the probe is outside bed area.
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
#endif
[/code]
As the X value is a negative value (-0.1) it looks as if that is the problem, as that would trigger a software endstop. Are you sure that #define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS. ========changed from true to false PC======= is set to false?
