Audio k 8060
my k8060 is blowing when i was playing, the fuse was blowing, the amplifier give short cut between the transformer conection and between the speaker connections + and -,what can be the problem?
is it possible that the power diodes are broken/blowing?
Most likely, one or the two power transistors have shorted.
It is recommended to replace ALL transistors when this has happened.
Make sure to check all diodes too.
