After calibration head try to broke the bed
I go to Vertex calibration, do calibrate height first, then Auto calibration
Led blink every time printer is doing calibration
If I then go to Vertex calibration menu. select any of Calibrate X, Y or Z selection
printer head start banging bed hard
Same happens if i go Vertex calibrate Center and select Move Z
You can look video here in OneDrive, keep sound on when looking
https://1drv.ms/v/s!AvT7_SmVRRfqgddyews84FDSuPiS_w
What is idea of Vertex calibration “Calibrate X, Y or Z” selection?
Can i only look or can i adjust them and save them in memory
What is idea of Vertex “calibration” “calibrate Center” and select Move Z
Can i only look or can i adjust Z and save them in memory
Do You have any idea why printer is acting like this?
Jukka
Firstly you need to check the position of the endstops. The manual states that they need to close to the idler pulleys.
Can you post a picture of your endstop positions?
Also if possible can you post a movie of you calibration routine?
Sincerely
Hi
First is it possible you fix my account, so iI could write more than 3 post under subject?
You was right :slight_smile:
My end stoppers were too low
I adjusted them like this:
https://1drv.ms/u/s!AvT7_SmVRRfqgddzQVdBeMqUTcG4Pg
Now print head do not bang anymore
After calibration i look X,Y and Z
They show all value +004.6
Also “calibration” “calibrate Center” and select Move Z
Is this value correct?
And can you please answer to this too:
Jukka
I will forward your question about your account to the admin.
The idea of the XYZ CENTER calibration menu options is purely for checking if the calibration routine completed succesfully. You cannot change anything with these menus.
